700r4 lockup internal wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2008, 10:13 AM
gearhead77's Avatar
New Member
Last journal entry: brakes, tranny & distributor
Hello all,
I have an '88 700r4 that I am prepping to install behind my 400 SBC. So far I have put in a shift kit and gathering parts for a mechanical speedo swap.
I would like to set it up internally to have a 1-wire lockup. I found a page that I think Crosley made immensely helpful http://www.geocities.com/crosley_az/lockup1.htm.
Mine appears to be a little different from his, so I wanted a quick check-in and feedback on a quickie wiring diagram I made, based on the photos in his site. I started a new thread, since many recent threads seem to only deal with wiring the lockup from the outside. The pics are of my trans upside-down with the pan off and the front at the top of the photos. The pdf wiring diagram assumes the same orientation.
Is the wiring diagram correct? Either way, please let me know and it can become part of the knowledge base or I can correct it to make it useful for that purpose.
I do plan to test my position "A" switch to ensure it is good and Normally Open by the method outlined in pages linked above and remove the thermal sensor and remove & block off the other (dark/normally-closed? 2-prong) switch/sensor.
Thank you in advance for sharing you knowledge.
ID:	29291   Click image for larger version
Old 04-15-2008, 08:16 PM
Crosley's Avatar
Wiki Edits: 1659
I took a quick look at diagram. it appears correct.
It is a simple 12 volt circuit with the NO switch provides ground in OD.
the correct port is the pictured silver switch with single connector pin.... blue(?) connector on it.
Old 04-16-2008, 07:14 AM
gearhead77's Avatar
New Member
Thank you for your response and expertise!
Need help wiring my 700r4 409guru Transmission - Rearend 3 01-21-2008 02:02 PM
700R4 LockUp wiring diagram chevychase Transmission - Rearend 7 07-30-2007 09:23 PM
700r4 lockup engaged directly after shift into second?? ferociousd Transmission - Rearend 3 07-22-2007 09:32 PM
Internal Reaction (Ring) Gear shattered in 700R4... indy_85stariones Transmission - Rearend 8 11-30-2006 05:31 PM
700r4 parts and lockup wiring McDeuce Transmission - Rearend 17 12-17-2003 07:52 PM
