700r4 lockup method confirmation - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2012, 10:39 AM
I'm putting an '87 700r4 in my '76 C10 and I've read to get the TC to lockup... I can supply 12v to the front outer pin and jumper the remaining 2 pins together(in the white 4 pin connector on driver side). If this is correct, it would lockup in 4th all the time except when brakes are pushed(using a switch at the brake pedal). Which would technically be all I'd have to do but I've also read that using a vacuum switch will unlock it under acceleration. Which is a good thing... correct? What are you guys' thoughts/opinions/facts on all this?
Old 08-10-2012, 05:19 PM
I think the minimum requirement for controlling the TCC lockup is:
1. brake switch with NO contact for brake lights and NC contact for providing lockup 12v
2. toggle switch on dash to turn off lockup when not needed at slow speeds in 4th gear
3. vaccum switch in engine compartment to disengage lockup under high throttle conditions.
Run power from the NC brake switch thru the toggle switch then thru the vacuum switch to the electrical connection on the trans.
If you are into electrical gadgets, for even better operation you can add a time delay switch and/or a rpm or speed switch to reduce cycling of the lockup under certain conditions.
John
Old 08-11-2012, 05:21 AM
SSedan64's Avatar
Yes, Brake Switch from a vehicle that has Cruise Control or a TH350C/250C/200C, TH700R4, TH2004R Trans etc.. will work.
TCC Plug Pin diagram >> http://www.hughesperformance.com/pdfs/HP700-R4.pdf
GM 4-Pin Brake Switch #25524845
TCC Pigtail > GM Transmission Converter Clutch Pigtail Connector - The Repair Connector Store
Old 08-12-2012, 03:47 PM
Great, thanks guys!
Converting non-lockup 700R4 to lockup V8TEC Transmission - Rearend 7 09-10-2011 10:25 AM
700r4 Lockup ? steven_1104235 Transmission - Rearend 3 03-29-2010 05:42 AM
700r4 Lockup lelshaddai Transmission - Rearend 11 08-04-2008 02:23 PM
700r4 lockup stevo71 Transmission - Rearend 2 05-10-2008 12:57 AM
700r4 lockup hdbiker Transmission - Rearend 4 02-20-2006 01:52 PM
