700R4 Lockup question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2005, 12:39 AM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
I'm confused..... after looking at the the following pages: http://purplesagetradingpost.com/sum...o/700R4p1.html
According to the second diagram, if I energize term A and ground term B, I should have lockup on gears 2,3 and 4. Is this correct? I am running a 2500 converter, and most of my driving is at 1500-2000 rpms. Should I wire up the trans , so it locks up 2,3,4 ? So the trans temp stays within normal range.
Thanks,
Bob
Old 05-08-2005, 10:25 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
what is the weight of the vehicle? Weight plays a large part of converter heat buildup.
As the weight of a vehicle goes down ... the converter stall speed must go up to avoid the engine pushing against the brakes while at a full stop
You do not want to shift the tranny while the converter is locked up. That is very hard on the lockup hub inside the converter.
I provided a large part of the tech 700 information to the Purple sage owner, although I did not provide the drawings... , He is a good friend of mine
Thanks,
Bob
Old 05-08-2005, 12:55 PM
AngliaBob's Avatar
Crosley,
The vehicle weighs about 2500lbs, 2400-2600 coverter and 3:89 gear ratio.
Judging from your reply, I should wire up for 4th gear lockup only.
Thanks,
Bob
converter lockup power question guba_unus Electrical 5 01-11-2005 07:49 PM
700R4 Mounting Question mike bryan Transmission - Rearend 6 11-05-2004 06:14 PM
lockup converter question Neophyte Transmission - Rearend 1 06-08-2004 08:16 PM
700R4 non lockup Jagwar Transmission - Rearend 0 04-12-2004 11:22 PM
700r4 band question chevcamz28newbie Transmission - Rearend 0 08-05-2003 01:46 AM
