We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 02-27-2003, 06:04 PM
phillyfab phillyfab is offline
Post 700R4 losses reverse after towing on a dolly?
Last week in my haste to get to a hybrid event at my local track I rented a tow dolly..I know that you were supposed to pull the driveshaft to prevent tranny damage but i didnt have any fluid and was plain cheap/lazy..When i arrived at the track the car wouldnt move in reverse..It was like it was there and then went away..Now back at the house i have to rev it way up to get reverse wich is really weird..All the forward gears work great and it even shifts automatically fine..Im not sure if the trans was in netural when i pulled it and im thinking just a band is worn out..Possibly backfeeding pressure through the fluid while towing..Any insight would help..
Old 02-27-2003, 09:12 PM
jc55 jc55 is offline
Post
Automatics are not self lubricating like manual transmissions. They are lubricated by the front pump which is turned by the engine...yup, you broke it.
Old 02-28-2003, 11:50 AM
lamothe1's Avatar
lamothe1 lamothe1 is offline
Post
Without the engine running to turn the front pump there would be no lubercation to the clutches or bands. it's just a matter of time with all those parts spinning around that things will burn out. There's probably isn't any friction material left on the reverse clutches. All you can do it rebuild it.
[ February 28, 2003: Message edited by: lamothe1 ]</p>
Old 03-02-2003, 04:38 PM
airworld2's Avatar
airworld2 airworld2 is offline
Post
sorry to say but in the future remove drive shaft when towing any automatic transmission car or truck most likely burnt out rear planet on 700 r4 trans
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
