Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 lost 3rd gear
  #22 (permalink)
Old 03-11-2013, 07:49 AM
ASE Doc ASE Doc is offline
I believe I promised to post a parts list when this project was completed and tested to my satisfaction. Here is that list beginning at the front of the unit.
2,800 stall converter with balloon plate
Hardened input shaft(as was used behind the LS1)
Rebuilt 10 vane pump with high rev slide spring
Sonnax line rise kit with .500 TV boost valve and stiffer spring
.300 reverse boost valve
New reverse input drum
Extra wide carbonite 2-4 band
Superior 2nd servo
Superior 4th servo
Sonnax Smart Tech input housing
Beast sun shell
All new clutches and steels including 9/.062 frictions and 8/.077 steels in the 3-4 clutch(one of the .077 steels was replaced with a .106 steel to set clearance at .050)
All new thrust washers and bearings
TCC solenoid
Dual springs in the line bias valve(the red spring from the Transgo JR shift kit and a spring from the hardware store that fit inside it)
Transgo CS7 high rev springs for the forward and 3-4 clutches
Other mods were already made to unit in the previous build and were reused including corvette governor and Transgo 3-4 shift valve.
