700r4 Low/Reverse Clutch Pack - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2007, 01:46 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
I pulled out the low/reverse clutch pack and piston to check specs as I got more info from my new book ( 87-93 ) which I know you guys hate but its all I got to go on.
The height of the piston does not match any specs in the guide.
The clutch pack according to the guide should have a wavy plate and a selective plate. The burnt out clutch pack I pulled out didn't have either of these. I'm wondering if I have earlier parts in this tranny or something was swapped out at some time.? I bought this tranny used,so I don't know the history on it.
Thanks,
Pugsy
Old 12-28-2007, 08:42 PM
Crosley's Avatar
Wiki Edits: 1659
Thanks,
Pugsy
GM used multiple l-r piston , steel , friction, wavey , thick steel plate stack ups in the trans.
Early 700 were, piston with 5 x5 steels and frictions. No waves , or thick bottom plate with wavey
Set the piston in case NO seals, stack up steels and frictions , set center support on top. Check for clearance... .050 to .070 will function.
Install snap ring if you wish and pry the clutch pack apart with a scribe for a more accurate measure of clearance.
Some times there is additional gap above the snap ring which will open up the clearance a bit.
Old 12-29-2007, 08:31 AM
123pugsy's Avatar
Wiki Edits: 29
Thanks Crosley. Will check this out.
700R4 clutch pack air check question jws Transmission - Rearend 10 05-08-2007 08:23 PM
Rebuilding a 700R4 in 4x4 for towing... indy_85stariones Transmission - Rearend 4 02-02-2007 01:26 PM
700r4 forward clutch pack Caesar_Mikey Transmission - Rearend 2 04-17-2005 12:51 PM
th350 low roller clutch and 700r4? Tissue Transmission - Rearend 4 05-16-2004 10:23 AM
bowtie sight, clutch pack and servo help chevcamz28newbie Transmission - Rearend 1 07-30-2003 11:36 PM
