Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 Low/Reverse Clutch Pack
Old 12-28-2007, 08:42 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
Originally Posted by 123pugsy
I pulled out the low/reverse clutch pack and piston to check specs as I got more info from my new book ( 87-93 ) which I know you guys hate but its all I got to go on.
The height of the piston does not match any specs in the guide.
The clutch pack according to the guide should have a wavy plate and a selective plate. The burnt out clutch pack I pulled out didn't have either of these. I'm wondering if I have earlier parts in this tranny or something was swapped out at some time.? I bought this tranny used,so I don't know the history on it.
Thanks,
Pugsy
GM used multiple l-r piston , steel , friction, wavey , thick steel plate stack ups in the trans.
Early 700 were, piston with 5 x5 steels and frictions. No waves , or thick bottom plate with wavey
Set the piston in case NO seals, stack up steels and frictions , set center support on top. Check for clearance... .050 to .070 will function.
Install snap ring if you wish and pry the clutch pack apart with a scribe for a more accurate measure of clearance.
Some times there is additional gap above the snap ring which will open up the clearance a bit.
