Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 Lurches forward when in neutral
Old 01-10-2010, 02:30 PM
alittle1 alittle1 is offline
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
In a word, leakage.
The fluid which builds up pressure is leaking past check valves and spring loaded ball bearings and the fluid is applying pressure to the clutches.
So, why are you revving it to over 3000 rpm if it is doing this? Your like the guy who works in a saw mill who says, Every time I stick my finger out like this.....whoops, there goes another finger....".
