700R4 manual shift option only opinions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2011, 05:39 PM
russ69coupe's Avatar
Last journal entry: starting to go the right direction
Hi. Going to be building one of these for my 70 Lemans. Already know about the upgrades needed.
My question is if anyone has experience using a manual shift only on the street with these? Frankly, the tv cable thing worries me, so thinking about a manual valve body as an option. I really would like a 5 speed manual trans anyway, but the budget won't allow that at this point.
Thanks,
Russ
Old 10-13-2011, 04:15 AM
SSedan64's Avatar
Most Manual VB's have full/max Pr. or Constant Pr. & can cause premature Pump wear. For a daily driver this could be a problem. Shifting every gear can be a pain also.
The TV Cable adjustment really isn't a problem, just need the correct Brackets.
Old 10-13-2011, 04:57 PM
Thanks.
Shifting is fun, but I don't want to have to replace the pump often either.
I knew there had to be an issue with doing that.
Russ
Engine option opinions wanted.... woodscavenger Engine 22 01-24-2011 03:29 PM
4L80E manual lockup option? Bald Menace Transmission - Rearend 8 10-04-2009 11:53 AM
opinions on B&M street/strip shift kit? mattmar Transmission - Rearend 4 04-30-2009 08:32 PM
Manual shift 1cleanmav! Transmission - Rearend 4 12-09-2007 04:07 PM
What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 AngliaBob Transmission - Rearend 3 04-23-2005 11:25 PM
