Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 to Manual Swap-1991 Chevy 1500?
Old 11-03-2011, 01:54 PM
matt167 matt167 is offline
Wiki Edits: 31
a 4.3 NV3500 from a S10/ blazer will work with a 350, but for the C/K, the shifter is in the wrong spot.. For a bolt in 'sporty' transmission. The '93-'95 NV-3500 would be the hot ticket. It bolts in with donor parts ( x member, pedals and driveshaft ).. '96 had some changes to the clutch setup but the trans is the same.. 3500 does make noise and isn't known for reliability, but it's decent.. C/K's had the wide ratio, but I drive 1 every day, and have no issue with it
