700r4 md8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2013, 04:06 PM
700r4 md8
I was wondering if anyone knew the specifications for the accumulator springs. I have found trauma and very different springs in the 1-2 & 3-4 positions and from what I can gather from part descriptions there is a part specification for the 1-2 spring but not the 3-4. Is there a difference ? The 3-4 spring is significantly smaller in the sense of strength. The 3-4 piston was clearly oscillating a lot, mud big time. If someone knows a part number for each, that would be great.
Any advice ??
Thanks
chips
Old 03-25-2013, 05:50 AM
SSedan64's Avatar
700R4 Servos & Accumulators Transmission Parts
https://www.wittrans.com/SchematicPa...4&LinkCode=926
The Following User Says Thank You to SSedan64 For This Useful Post:
chipsA (03-25-2013)
Old 03-26-2013, 07:24 AM
pricesgarages's Avatar
i use flat washers and bring the piston to the beveled part of the case for 4th provides a quick shift into 4th as for the 1-2 i use a a th 350 2-3 accumlator spring
what does it mean i took a md8/ 8out have a md8/17 moosehead82 Transmission - Rearend 0 07-29-2011 02:32 PM
Removing a 2.8/700r4, Install V-8 with 700r4 1230firebird Transmission - Rearend 4 09-17-2007 05:17 PM
700R4 again.. Mechassault_x Transmission - Rearend 0 05-14-2007 05:29 PM
700r4 C.sheppard Transmission - Rearend 0 10-19-2005 11:30 AM
What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 AngliaBob Transmission - Rearend 3 04-23-2005 11:25 PM
