700r4 to muncie 4 speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2009, 03:10 PM
wondering if anyone has swapped a 700r4 to a 4 speed manual and what will be necessary to do so.
Old 04-06-2009, 03:11 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
well it all depends on what you are working on.what type of vehicle is it. cole
Old 04-06-2009, 03:59 PM
its a 1968 pontiac catalina...engine is a 350 chevy small block. originally the car had a th400. not sure what length of th400 it was. all i know now is that it has the 700r4 out of a late 80's chevy van.
Old 04-06-2009, 07:29 PM
68 catilina is based on b body platform general motors design . early chevy impalas in same year are more readily available with that option .i traded a parts car to a friend of mine that has a junk yard a couple of years ago that was 3 speed stick on floor from factory . it had clutch and brake pedal setup still in it . it was a 67 b body and would work .there are some impala restoration specialists out there that may stock the parts you need to change it over to manual transmision
Old 04-06-2009, 08:13 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Gonna need to locate a brake and clutch pedal from a Pontiac--big car.
Clutch pedal rod as well.
Might need the entire pedal support.
cannot recall if the Z-bar bracket was welded or bolted on tho.
I used to see a lot of 3-speed big pontiacs.
And have actually seen more Catalina/Ventura with a 4-spd than Chevrolets.
(cars actually driven---not the restos in shows)
Went to school with a guy that had 2 4-spd 2+2 cars (way cool), 65 & 67
This same guy is the present owner of a 67 Grand Prix Convert (only year for the convert)
Old 04-07-2009, 11:45 AM
http://www.impalas.com/transmission-...ackets-shafts/
http://cgi.ebay.com/ebaymotors/67-68...Q5fAccessories
would this be some of the parts i would need?
Old 04-08-2009, 10:23 PM
them would be what you need on ebay clutch brake pedal then you would need z bar and piece that welds to your frame for z bar and ball stud for your block and rod from pedal to z bar and rod from z bar to throwout bearing fork that was listed on impala site
I picked up a 400 SBC and a M21 4 speed Mustangsaly Engine 22 03-05-2010 09:32 AM
4 speed Muncie Help ?? super_silent Transmission - Rearend 14 11-22-2007 07:38 AM
Borg-Warner T-10 or Muncie 4 speed Chevy21 Transmission - Rearend 4 06-17-2005 08:58 PM
6 Speed swap from 700R4 arch Transmission - Rearend 1 05-16-2003 09:32 AM
Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed nightrain_rod Transmission - Rearend 2 04-18-2003 12:35 PM
