700r4, in need of assistance. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2008, 08:56 AM
i just rebuilt 700r4, put it back in got the T.V. cable set like it should be and take it for a test drive. it shift a little soon on the 1-2 shift but it does shift through all the gears pretty good. but my problem is that it will not down shift back to first. it down shifts fine through all the other gears, but will not drop back into first. if i manualy drop it in it will go or if i stop shut it off and restart it will start in first but just driving down the road it will not. i think my line pressure is low but i cant find anything telling me what they should be.
P- 60
r-90
n-60
od-60
d-60
2-100
1-90
any help would be great.
thanks
Old 07-14-2008, 10:21 AM
SSedan64's Avatar
Sound like your TV cable needs some more fine adjustment. Try to tighten it a click or 2. Check pressures for Minimum with TV cable with cable at Idle position. Check for Max pressure with TV cable fully pulled.
http://www.tciauto.com/Products/Tech...e_pressure.asp
Old 07-14-2008, 09:34 PM
I have it set to WOT, if i tighten it up a click, that will restrict my throttle movement. I will try it but that is my consern with doing it.
Old 07-14-2008, 10:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
your pressure readings are at OEM levels on an early trans(small reverse boost valve assembly).
Not shifting back to first gear at a full stop is usually the governor sticking or the v-body shift 1-2 valve sticking.
IF you try to pull the linkage further than WOT setting, stuff will bend.
Old 07-16-2008, 06:05 AM
pressure switchs
i pulled the valve body back off, and worked it over again. think i found and fixed the 1-2 sticking a little. discovered my pressure switches dont hold pressure, very well. there is 4 total and everything i am reading looks like that pretty much the only one that matters is the 4 gear lock up. should i replace all of them that leak or just get a new 4 gear switch and plug the rest of them. and if so what is the best way to eliminate the excess wire.
thanks.
Old 07-16-2008, 10:49 AM
1-2 shift.
it was the 1-2 shift valve sticking and problem solved. local transmission shop tells me that i need those pressure switches for it to work right as far as lock up goes. 60 bucks and problem i think will be all solved. still think it shifts a little early on the 1-2 shift but i think they sell a shift kit to help with that. any kits i should look for and stay away from, any info would be great thanks.
Old 07-16-2008, 11:18 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
I like the TransGo 700-JR. It's the only one I've used for the TH700's. You'll like it.
700r4 conversion questions eric63chevy2 Transmission - Rearend 7 07-03-2007 01:37 PM
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 02:04 PM
Rebuilding a 700R4 in 4x4 for towing... indy_85stariones Transmission - Rearend 4 02-02-2007 01:26 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 03:34 AM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
