Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4, in need of assistance.
Old 07-14-2008, 10:10 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
your pressure readings are at OEM levels on an early trans(small reverse boost valve assembly).
Not shifting back to first gear at a full stop is usually the governor sticking or the v-body shift 1-2 valve sticking.
IF you try to pull the linkage further than WOT setting, stuff will bend.
