Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4. No 2nd Gear, Slips in OD
Old 07-29-2006, 12:00 AM
Grit54 Grit54 is offline
if you have access to a trans manual,,the 6.2 TV cable has a different adjustment proceed. than other engine/trans combos,,so you need to check that out ,but the bad news is it has to come out,the 2-4 is the same band,but you also have overrun clutches and forward apllied, ran into the anchor pin on the band being sheared before,you could have servo problems to, get ready for some close looking ,,,,,,hope this is helpful
