700r4 .. no 3rd or 4th gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2006, 07:35 AM
700R4 tranny wont shift into 3-4: could it be a fluid line stopped up and how{in detail} and where do you check pressure?
Old 12-27-2006, 08:26 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
3 - 4 clutch failure is common on this trans since it was introduced.
Pressure port for main line is above the shifter linkage a couple of inches on the drivers side .
Fluid line clogged up? Unlikely.
What is the history of this tranny? Mileage, year, vehicle, any recent repair or service work ever performed?
I EDITED the thread title to let folks know what this post subject is about.
Old 12-27-2006, 09:49 AM
700R4..no 3rd or 4th
Yes 3-4 clutch failure is common,does it try to make a 2-3 shift,then goes to neutral?
The 3-4 clutchs are on in 3rd and 4th,if it goes to neutral, the 3-4 clutchs are done.
Or maybe it does not try to make a 2-3 shift,and there's no 3-4.
If this is the case,a gauge will be most helpful.
700R4 transmission no 4th gear fivewindowcoupe Transmission - Rearend 2 12-11-2006 12:27 PM
700R4 3rd & 4th lockup chrisape Transmission - Rearend 6 11-14-2006 06:25 AM
700r4 has no 3rd or 4th gears mattgabe Transmission - Rearend 5 06-27-2006 07:59 PM
700R4 will not shift into 3rd and 4th gear bebopwally Transmission - Rearend 14 05-25-2006 07:48 PM
Towing in 3rd with a 4th gear lock up kit in 700r4 wed68 Transmission - Rearend 4 03-25-2005 12:34 PM
