700R4 no 4th - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2012, 06:39 PM
700R4 no 4th
I have been chasing a no fourth issue for a while now. I have found that the 4th apply piston is dry(no oil between piston and servo cover). I have checked the servo pin and its clear of obstructions and a guy suggested checking the 3-4 relay valve and 4-3 sequence valve. I had a working but worn spare 700r4 so I swapped valves and springs, moves just fine.
Anyway does anyone know why there would be no oil goin through there?
Thanks
Need Help with 700r4 No 4th Gear Jackson63 Transmission - Rearend 7 04-20-2015 09:45 PM
3rd to 4th - 700R4 87GMC Transmission - Rearend 4 06-02-2009 07:28 PM
700r4.. no 4th gear? daoriginator64 Transmission - Rearend 8 09-23-2008 09:59 PM
700r4 - No 4th bobnance Transmission - Rearend 1 05-22-2008 12:48 AM
700r4 no 2nd or 4th BustedBowties Transmission - Rearend 9 11-04-2007 07:30 PM
