a 700r4 No 4th Gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2009, 04:16 PM
TAGTASCOTTY's Avatar
FIXER
a 700r4 No 4th Gear
Yeah it's a 700r4, This is a brand new tranny, Fluid levels correct, t.v. cable proppelry adjusted, shifting fine, but no 4th gear.... Any idea?????
Old 07-13-2009, 04:49 PM
tnsmith10's Avatar
when will it rain???
was there a shift kit installed? if so what kit?
just on the basic info, 1st place id look is the servo, maybe a cut or missing teflon seal.
Old 07-14-2009, 10:09 AM
FIXER
Yes there was a shift kit installed, but it is only a stage 1 kit.
Old 07-14-2009, 10:54 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
This may be a sticking shift valve, or a faulty governor.
Rich
Old 07-14-2009, 01:15 PM
FIXER
Hey guys, thanks for the input. tell me if you've ever heard of this....
I called the shop that built this tranny as it is brand new and way under warranty. The man that built it told me that occasionally they'll have them where I guess air gets trapped and wont shift to 4. Told me to get the revs as high as I can while in 3rd gear and it will "slam into 4th" and them problem is cured.. let me know what you think. I thought it was a pretty interesting concept.
Old 07-14-2009, 05:37 PM
tnsmith10's Avatar
who is the manufacter of the stage 1 kit? what kind of vehicle is this trans in? and what rear gear does the diff have? if its anything like the kit i have in my 700r4, if they changed the 3-4 shift valve spring, and the car doesnt have at least 3.73 rear gears, its likely to have a late shift into o.d. cause its meant for 3.73 gears or shorter like a 4.11 etc.
otherwise, id say 3-4 shift valve possibly stuck, or servo related or the thought of a missing checkball does come to mind. fact is,if it has no o.d. and theres a warranty, they need to stand by it.
Old 07-14-2009, 07:22 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I would disagree with the trans guy on that air trapped thing.
I suspect a stuck 3-4 shift valve .... a higher rate of RPM would raise line pressure and possibly force the shift valve to move as the trans guy suggests :"Slam in to 4th"
700r4.. no 4th gear? daoriginator64 Transmission - Rearend 8 09-23-2008 09:59 PM
4l6oe no 4th gear mahooody Transmission - Rearend 1 01-17-2008 05:25 AM
700R4 2nd gear start/4th gear bind up? myclone1 Transmission - Rearend 3 04-19-2005 02:51 PM
Towing in 3rd with a 4th gear lock up kit in 700r4 wed68 Transmission - Rearend 4 03-25-2005 12:34 PM
700r4 Skipping 2nd gear ThrottleBottle Transmission - Rearend 4 08-07-2003 03:52 PM
