700R4 no fourth - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2006, 01:26 PM
700R4 no fourth
I just rebuilt a 89 700R4 standard clutches and steels but 13 vane pump and the super 2-4 servo pistons. Shifts good lockup in 3rd but no fourth neither auto or manual shift. What could be the problem? I've had it up to 60, but it still doesn't shift to fourth. I changed the governor that did nothing diff.Thanks
Old 09-05-2006, 03:14 PM
700R4 no fourth
Wheres all our 700R4 Gurus?
Old 09-05-2006, 10:27 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you have the super servo setup incorrectly i bet.
the 2-4 servo is multi stage , incorrectly setup aftermarket servo & the pin cannot apply the band in OD since a different piston does the apply pressure for OD than for 2nd gear.
I resigned my mod position and seldom visit the site here. I am sure the other tranny pro's are still around . Perhaps real busy with work?
V6 or V8 700R4 swap? cacsmret Transmission - Rearend 4 05-05-2006 10:28 PM
2wd to 4x4 700r4 QUINTANA64 Transmission - Rearend 7 04-05-2006 06:20 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 04:34 AM
TH700R4 Slipping 4th only. eliotmansfield Transmission - Rearend 28 01-25-2005 02:23 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 07:44 PM
