700r4 no go In OD - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2005, 05:08 PM
New Member
700r4 no go In OD
OK I just got my 700r4 back in my blazer I put it in drive shifts fine and 1 2 3 and R fine. But when I put it in OD it doesnt move. give it gas and it acts like it wants to move. pulls a little. this is my frist ever rebuild could it be a cheak ball wrong?
Old 05-06-2005, 07:22 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
no go in OD? Does it go ( drive) fine in "D" ? OR ... no go in any forward gear on the shifter??
If NO go in OD only, drives fine in "D" ........ the forward input sprag is installed backwards
Old 05-07-2005, 06:09 AM
New Member
lol thats what I was thinking wooo get to pull it out and fix it. are you talking about the forwaed sprag? theres only one way it can go small side down? could a leak on the forward clutch piston cause this?
Old 05-07-2005, 01:50 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
if you did a proper rebuild , you had the forward input sprag assembly apart for cleaning / inspection /repalcement of the sprag.
The actual sprag will install either direction in the sprag assembly race assembly. One direction the vehicle moves. The wrong / backwards installation, the vehicle does NOT move with the shifter in OD.
Old 05-07-2005, 03:16 PM
New Member
i had it apart but I dont think thats the problem. Could not have the cluchs right in the foward pack do this. It acts like it wants to go but doesnt. it [pulls a little but not much at all.
Old 05-07-2005, 08:47 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you bet.
tear the tranny out and apart. Let's see what the problem is
Old 05-08-2005, 05:43 AM
New Member
well I went out there this morning and put it in OD and gave it gas. It took some rpms like 2500 but it started to move so its like its a super slip. what could cause this?
Old 05-08-2005, 08:25 AM
Jmark's Avatar
Ceaser Mikey....
The man who has been answering you is a professional full time tranny builder. Asking again and again won't get a different answer. If it were me, i'd listen to him. Sprag is probably in backwards and continuing to rev it up trying to make it move won't be too good for it either.
Mark
Old 05-08-2005, 09:06 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I asked these questions:
No movement in OD? Does it go ( drive) fine in "D" ? OR ... no go in any forward gear on the shifter??
If NO movement in OD only, vehicle drives fine in "D" ........ the forward input sprag is installed backwards
I did not recieve answers that I have noticed.
When you move the shifter to "D" position, another set of frictions are applied ( Over run frictions) these frictions while move the vehicle forward
If you run the engine RPM high enough , long enough while in OD while the vehicle does NOT move....... "IF" the sprag is backwards and causing NO movement. You WILL gall/over-heat/damage the forward sprag and races it rides on AKA ruin the parts
Originally Posted by Jmark
Ceaser Mikey....
Mark
Old 05-08-2005, 12:14 PM
New Member
ok I just got into it and the sprag is right what else could it be? and the D works fine but when you put it in OD it doesnt move
Old 05-08-2005, 06:40 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
does the forward clutch pack air check good?
Is the seal rings there?
IS the forward clutch piston cracked?
Is there any cracks in the aluminum drum anywhere?
IS there cracks in the input shaft?
SPRAG assembly test: As you hold the small race ( part that goes down in the aluminum drum) assembly in your right hand.... use your left hand to spin the larger ( outer) race..... does the larger race spin counter clockwise ?
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
700R4 vs Gearvendors OD bootshd Introduce Yourself 1 11-28-2004 04:14 PM
700R4 no OD weird andrewhotrod Transmission - Rearend 5 07-16-2004 06:17 PM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 07:59 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
