700R4 no line pressure rise - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2008, 04:17 PM
Hi everyone, I have a 700r4 that i just changed valve bodies on, After doing everything i put a pressure gauge on the main line pressure port, and i noticed the pressure was 75psi, but this does not change at all when i pull the TV cable tight, it just stays at 75 all the time. Is there something i could have missed that would cause this?
Old 07-06-2008, 08:33 PM
SSedan64's Avatar
Are you sure the TV cable is connected to the Throttle Valve inside the trans?
http://www.tvmadeez.com/article/index.php
Old 07-07-2008, 07:51 PM
Yes, im sure that the cable is connected to the throttle valve.
Old 07-08-2008, 07:08 AM
SSedan64's Avatar
Which pressure port are you hooking the gauge to?
Old 07-08-2008, 11:45 AM
Im hooking the gauge up to the port on the drivers side of the car just above the shifter linkage.
Old 07-08-2008, 11:03 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
many things could cause this problem;
wrong v-body installed.
Stuck inner TV valve...
TV inner valve installed incorrectly at retaining roll pin.
TV linkage not hooked up or installed correctly.
Gaskets miss installed.
just a few items that come to my mind
Old 07-09-2008, 07:04 PM
The valve body was off the same year tranny, everything looked identical on it, except where the lock up solenoid was. IT was just in the next port over. How do you verify that it is the right valve body the I took it back down and verified that the tv valve is installed correctly and its free, the gaskets appeared to be in place, the Tv linkage is pushing on the plunger when you pull the cable. Could something inside the tranny itself be causing this pressure not to rise? im stumped Also i double checked and all the check balls where in the right spots too.
Old 07-11-2008, 08:26 PM
HEy everyone just wanted to let you know that it ended up that the pressure was fine the whole time , turns out the pressure gauge was getting stuck at 75 and wouldnt read any higher, after having the valve body on and off about 3 times i noticed this...... put a new gauge on and it was right where it should be, the old gauge got the sledge hammer treatment and went in the garbage
Old 07-11-2008, 08:40 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Wow, what an exercise.
Faulty tools, appliances often get the coupe de Gracie with me drawing cross hairs on it with my .25-06.
Stress relief.
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 02:10 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
4L60E Line Pressure problem (possibly) olimpalarider Transmission - Rearend 13 11-20-2006 03:55 PM
WEIRD oil pressure christopher406 Engine 32 11-27-2002 08:49 AM
Fuel Pressure Variance slomotion Engine 2 04-02-2002 02:25 PM
