700r4 no over drive - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2012, 01:21 PM
700r4 no over drive
just got a transmission from junk yard 7oor and put it in shifts though all gears but wont go into overdrive at all i have adjusted the tv cable all ways that i know how is there anything that i am missing cause it is killing me in gas not having overdrive any body please help my wallet would really thank you
Old 07-15-2012, 09:29 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
year, make , model, mileage on this vehicle? With a junk yard trans , it can be a crap shoot if it works correctly
The trans can not be shifting all gears if it does not go into over drive.
In a 700r4 trans there will be 3 shifts from a complete stop. 1 - 2 shift, 2 - 3 , then 3 - 4 .. Converter lock up would happen too IF the proper electrical connections are made
Bad 700R4 -- OK to drive/move? autonerd Transmission - Rearend 3 02-21-2012 04:04 PM
700R4 Not working in drive hotroddin78 Transmission - Rearend 10 05-08-2011 12:46 PM
700r4 Slipping In Drive EDDIE5394 Transmission - Rearend 4 04-19-2009 08:33 PM
700r4 ... shifts late to over-drive hotrod3z Transmission - Rearend 12 01-09-2008 09:16 AM
Drive test 700r4 Blackdog Transmission - Rearend 3 05-20-2005 09:21 AM
