700R4 No Overdrive - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2007, 03:32 PM
700R4 No Overdrive
I just overhauled my 87 GMC S15, 700R4 tranny but no overdrive.
I checked all the usual suspects but I don't know whats wrong.
If anyone has any ideas, please let me know.
Thanx.
The Dabbler
Old 10-29-2007, 07:36 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanx.
The Dabbler
is the band servo components properly installed?
Was the band servo pin length checked?
Is the shift valve stuck?
Was the bore for the accumulator in good condition?
Was the accumulator piston pin bore worn out?
Is the TV cable set & adjusted correctly?
that is a start
After market overdrive or 700r4 Jared Engine 7 12-08-2008 02:19 AM
Overdrive in 700r4 av8r Transmission - Rearend 2 08-04-2007 08:59 PM
700R4 or TH400 w/ overdrive 53LEDSLED Transmission - Rearend 8 05-28-2007 09:22 AM
700r4 vs. th350 with VOD overdrive steemin Transmission - Rearend 12 01-09-2006 01:25 PM
700R4 won't hang in overdrive slingslingbinks Transmission - Rearend 8 03-29-2004 10:43 PM
