700r4 no overdrive - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2005, 07:09 PM
700r4 no overdrive
I just installed a used 700r4 in the WarWagon ( 90 GMC fullsize 350) I flushed out the cooler lines and all that good stuff but now I have no overdrive. It will shift into OD, but only when I am not touching the gas -i.e coasting down a hill - but as soon as I touch the gas it goes back to 3td. If any one knows a way to fix this short of a rebuild please let me know. The transmission came out of an 87 3/4 ton van that had been sitting for several years. Thanks
Old 05-24-2005, 10:22 PM
Mr Ed's Avatar
is it a kickdown cable adjustment. i'm not that familiar with the 700r but on the earlier chevy trans there is a cable from the accelerator linkage on the engine to the trans and if it is too short or adjusted out too far it will cause the trans to stay in 2nd too long etc. just a thought.
Old 05-24-2005, 10:41 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the 700/4L60 trannys have a Throttle valve cable aka TV cable.
It must adjusted correctly.
I would check that adjustment first. Full pull of the calbe at WOT is the place to set the TV cable at.
Old 06-02-2005, 09:22 PM
Roadsire's Avatar
Last journal entry: Dash mods
700R4 Website
Check this website out it should help you out and then some
http://www.purplesagetradingpost.com...o/700R4p1.html
Good luck
Old 06-07-2005, 05:52 PM
TrannY i put in 2 weeks ago went **** up after 5 days. It locked into second and that was it. I put another one in it and behold it works ( knocking on wood, crossing fingers. hunting for rosary beads) for now
After market overdrive or 700r4 Jared Engine 7 12-08-2008 02:19 AM
700R4 or TH400 w/ overdrive 53LEDSLED Transmission - Rearend 8 05-28-2007 09:22 AM
700R4 won't hang in overdrive slingslingbinks Transmission - Rearend 8 03-29-2004 10:43 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 07:44 PM
Bowtie Overdrive 700R4 WayOutCat Transmission - Rearend 11 02-04-2003 08:41 AM
