700r4 no reverse
i got a 90 gmc that all forward gears work but no reverse. I unhooked the drive shaft and put it in reverse and the drive shaft turns but when hooked back up still no reverse. not sure why can someone help
trannies smoked
Sounds like the reverse input clutch pack is bad. Are you sure you have 1 - 2 - 3 and over drive (4th).. IF the drive shell splines break , you will lose 2nd gear , reverse and over drive (4th).
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| 700r4 4x4 1989 reverse gear works half the time | MuscleBlock81 | Transmission - Rearend | 3 | 08-22-2007 08:50 AM |
| 700R4 slips in reverse | rdjern | Transmission - Rearend | 6 | 08-08-2005 08:24 PM |
| Rebuilt 700r4 - no reverse | Anton | Transmission - Rearend | 5 | 06-10-2005 10:55 PM |
| 700R4 losses reverse after towing on a dolly? | phillyfab | Transmission - Rearend | 3 | 03-02-2003 04:38 PM |
