700r4 no second gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2004, 12:54 PM
HI
This is a fresh rebuilt 92 700r4 with a TCI manual valve body and all of the sudden I have no second gear it acts like it's in neutral when I shift to second all other gears work fine.
Thanks for any suggestions on where to look first..
Virgil
Old 06-09-2004, 08:05 AM
67 Nova 400sbc.4L60
No Second gear
Does it shift first then third gear , does it have fourth gear. Does it have reverse. This helps in diagnosing the problem fully, Thanks Paul.
Old 06-09-2004, 08:57 AM
Rhansen's Avatar
Footbraker
If it has every gear except second I'd suspect that one of the seals on the servo came off during installation.
Old 06-09-2004, 04:27 PM
Hi
Thanks for the help just finished pulling the servo and all the seals were there I was hoping that was it.
Guess I'll drop the pan and check the 1-2 accumulator.
This has a manual valve body so you must shift manually it has no automatic shifts and all othe gears work great.
Thanks again Virgil
