700r4 no shift!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2005, 01:20 AM
700r4 no shift!!
This is a 1986 Chev 4x4 with 700r4 trans. It will not shift out of 1st gear ever. Reverse is fine and 1st is fine but, no matter what I do, no shifting out of 1st. I've rebuilts the valve body. No help. I've cleaned the governer. No help. I've taken the servo out and cleaned. No help. What else can it be. I've also made sure the TV cable is free. Thanks in advance for your help!!
Old 07-19-2005, 04:42 PM
DoubleVision's Avatar
You mentioned the TV cable is free, meaning it`s in adjustment? The cable must be in adjustment, if it`s not in correct adjustment it won`t shift. I would make sure the cable isn`t broken somewhere you can`t see it or if it`s come loose from the rod in the tranny.
Old 07-19-2005, 07:05 PM
New Member
I had a similar problem. My TV cable was too far out at idle so that it couldn't shift out of first. Try letting it back in a little and see it that makes a difference.
Transgo Shift kit "stick mode" 700r4 eliotmansfield Transmission - Rearend 11 05-03-2005 09:22 AM
700R4 shift points AngliaBob Transmission - Rearend 3 04-21-2005 12:00 AM
700r4 won't shift at WOT Alex99 Transmission - Rearend 39 02-15-2005 10:08 PM
c10 - th350 to 700r4 swap column shift 70chevyc10 Transmission - Rearend 7 10-25-2004 10:35 AM
More Info, High RPM to Shift on 700R4 Ted Bundy Transmission - Rearend 3 11-25-2003 06:44 PM
