700r4 no shifting - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2007, 02:34 AM
700r4 no shifting
hey, im new to the forum.
I just had a rebuild now it wont shift out of first! dont know what to do or check for. anybody have an idea? please help! only car i got
THANKS
Old 05-05-2007, 08:14 AM
no shift
The last time that happened to me it was because the kick down was stuck open .check the cable for adjustment length at the carb/efi air inlet or for kink's in the cable.you can also check the connection at the transmission to make sure the hook for the cable is not caught up on anything.. Is there a chance the rebuild may be faulty...
Good luck. hope this helps. omega69
Old 05-05-2007, 11:31 AM
THANKS looking into it right now.
nope it doesnt work
Old 05-05-2007, 12:16 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
plastic governor gear broken?
Under round press on cover near tail housing is the governor.
TV cable adjusted properly?
Minimum setting is important so the trans does not go into fail safe mode ( shift late) .
Stuck valves inside the body?
Old 05-05-2007, 12:44 PM
tv cable is adjusted,
im not touching the valves, dont know what to look for
how do you take off the governor? and where would i get a new one? autozone dont sell one. im in Dallas Tx
THANKS
Old 05-07-2007, 09:36 PM
replaced the governor, now it shifts but very late and also feels like its slipping any ideas????????
thanks
Old 05-07-2007, 11:20 PM
jakeshoe's Avatar
I wouldn't drive it until you sort it out.
Who rebuilt it. Warranty?
I'm local and do transmission work if you don't get it sorted out.
Old 05-14-2007, 12:53 AM
its been a while but i got it running right! man its hell when you don't have a jack(someone stole my jack )but its shifting good only one problem left!!! it takes off real slow but picks up real quick,.............. any ideas ????
thanks
700r4 shifting 123pugsy Transmission - Rearend 11 11-27-2006 07:39 PM
700R4 not shifting Stuckinthemud Transmission - Rearend 5 03-04-2004 09:01 AM
700r4 camaro shifting chevcamz28newbie Transmission - Rearend 1 07-21-2003 10:21 PM
700r4 shifting gears to soon alexdubois3 Transmission - Rearend 1 12-15-2002 06:01 AM
700R4 Shifting Points vernw Transmission - Rearend 0 10-30-2001 05:28 AM
