I did 4 complete overhauls in the past year.
400 miles everything was running great, few days ago no upshift again - only first and reverse.
I checked line pressure with TV cable pulled and released
Looks like the TV valve is stuck on full open.
Last time I open the valve body (400 miles ago) the TV valve was moving freely.
Tv cable released
started the engine (cold) pressure at P was at 70psi and then 20 sec later jumped to 125-130 psi and stays there.
P - 125psi
R - 190psi
N - 140psi
OD - 130psi
D - 130psi
2nd - 140psi
with the cable fully pulled
P - 140
R - 190
OD - 140
D - 140
2nd - 140
How do I fix it?
The Tv valve has the little aiding spring.
Tv cable released
P - 125psi
R - 190psi
N - 140psi
OD - 130psi
D - 130psi
2nd - 140psi
P - 140
R - 190
OD - 140
D - 140
2nd - 140
How do I fix it?
