700r4 noise shifting to 2nd - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2012, 07:03 PM
0pyders's Avatar
transmission has been sitting for a couple of years and it worked fine before I pulled it for an engine swap. So I must have installed something wrong.
I've got the rear wheels in the air and whenever I put it in drive and it shifts into 2nd immediately it makes this whirring/buzzing noise and the mph gauge jumps up 60 70 80 really fast. I'll hit the brakes and then it goes away back into 1st. Doesn't make a noise in any other gear. I've got the tv cable where its at max pull at WOT.
Anybody have any ideas? This is really frustrating me.
Old 06-29-2012, 09:35 PM
0pyders's Avatar
Also wanted to add that when I removed the pan it looked really clean. No metal, good fluid color. The whole thing works perfectly except when it has to shift by itself. And the noise pitch increases/decreases with mph/rpm.
Jeep T-400 shifting, skips 2nd gear kevinz Transmission - Rearend 9 12-15-2011 01:46 PM
4L60 shifting at redline from 1st too 2nd jody chevelle Transmission - Rearend 10 10-03-2010 10:49 AM
700r4 not shifting out of 2nd joeysworld Transmission - Rearend 7 06-30-2009 10:16 PM
700r4 shifting and 2nd gear . eliotmansfield Transmission - Rearend 4 06-20-2004 03:09 AM
Shifting problems from 1st to 2nd!!!!?? chevyelc81 Transmission - Rearend 1 07-08-2002 06:46 PM
