700r4 noisy after converter change
this is my friends car ive been helping with
92 camaro with a 3.1Lv6 that we turbocharged the stock converter started to blow threw pretty badly so he picked up a gm replacement converter gm16hd i belive was the number this is a high stall heavy duty converter basically used in the s10/15 pickups and blazers stall is around 2,800-3,000 rpms the problem is it has a chatter/clunking/buzz sound when the transmission is in manual 1 or 2, but dosent do it in any other gear or park and neutral heres are 2 videos so u can heear it first vid is from inside the car second video is with the camera under the car pointed at the flexplate/converter http://www.youtube.com/watch?feature...&v=hCJgPmlCzNc http://youtu.be/mkYyCjlrAj4 trying to figure out if the converter he got is bad or if the transmission is going out it does shift normally though and does not slip at all |
I hear the noise in all ranges,except P and N...louder in 1 and 2 for some strange reason..In a nutshell,I would pull it,check the pump stator support splines to see if they are stripped,check the flywheel...and if they look good...change the converter.
he spoke with dana at probuilt and it looks like the converter was just bad out of the box.going to have him insect the flexplate carefully when he pulls the trans to replace the converter again to make sure theres no small cracks in it,and to make sure all the mounting holes arent egged out or ovaled |
| New converter change in shift pressure? | 84Caprice57 | Transmission - Rearend | 6 | 09-15-2011 10:22 AM |
| 700r4 change over | bobandros | Transmission - Rearend | 2 | 03-20-2011 07:35 AM |
| Converter stall speed change | 65coupe351w | Transmission - Rearend | 1 | 12-01-2008 06:30 PM |
| Tx oil change, no converter drain | ScoTFrenzel | Transmission - Rearend | 2 | 07-19-2008 07:39 AM |
| Converter or Rear Gear change???? | voodoosurfer | Transmission - Rearend | 3 | 03-24-2005 10:43 AM |
