700r4 not shifting out of 1st gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2008, 02:41 PM
Whcih valve are you referring to, I am having the same problem, and it is a little harsh shifting into drive. Please help!
Old 08-09-2008, 03:16 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Check your governor for broken plastic gear. governor is under the round press on cover near the rear of the trans case.
Also check you TV cable for proper adjustment or perhaps the cable broke , cable end broken off at the EFI / carb linkage.
