700r4 not shifting to overdrive - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2013, 05:54 AM
I have a carbed sbc350 with a 700r4 in my rod. Been driving around now about 60 miles or so working out all the issues. I installed the kickdown cable and hopefully did it correct. When driving I noticed that it wont shift into fourth. The rest of them shift pretty good, a little rough compared to modern transmissions but I am guessing acceptable. Any ideas what is wrong. Will I kill the trans if I continue driving it without overdrive? Does the kickdown cable only affect the downshift? Is the overdrive an electric thing or a mechanical thing linked to the kick down cable?
Old 07-03-2013, 07:17 AM
It is actually a TV cable, or throttle valve cable, that controls the valve assembly. It is very different than a kick down cable . It is very important this set up right, if not you'll smoke the transmission very quickly. It sounds like your lock up is not hooked up correctly. Most lock ups are actuated with a break switch, vacuum switch, or combo of both. On side note it is o.k. to drive it with out the lock up hooked up
Old 07-03-2013, 07:22 AM
jokerZ71's Avatar
Wrench Turner
That is not a kickdown cable.It is the TV(throttlevalve) cable & it controls how & when it shifts.If not properly adjusted,you can destroy the transmission.It won't hurt it driving in D rather than OD.You should never use OD pulling,hauling a heavy load,or,in hilly terrain where the trans is constantly shifting between D & OD to maintain speed.The TV cable MUST be adjusted properly befor trans will shift correctly.
Old 07-03-2013, 07:48 AM
Roger Mabry's Avatar
Check out Bowtie Overdrives site..
You have to fix it quickly - the TV cable adjustment...should be adjusted with a pressure gauge.
Look at Bow Ties site for the "proper" way to adjust it...sounds like you have a 200R trans without an automatic OD lockup. It can easily be
added...same site.
They are great people and will help you, call them or look at the video of EZ TV adjustment. I have their kit on my car and it works perfectly...smooth
shifts by way....
Old 07-03-2013, 07:57 AM
jokerZ71's Avatar
Wrench Turner
I know the question may be silly,but,it has happened.You did install a proper lockup type converter????
Old 07-03-2013, 08:03 AM
I think i hooked up the tv cable correctly. I remember going through hell adjusting it at the carb. as far as the plug for the lock up is concerned, there is nothing there. Do i need to buy one and where do i hook it up. I imagine it comes with some sort of screw in type switch like a hydrolic brake light switch. Sorry not very familiar with this stuff.
Old 07-03-2013, 08:19 AM
jokerZ71's Avatar
Wrench Turner
The plug should be along with the harness from the trans.If your vehicle is not already equipped for lockup operation,you may have to wire into the proper circuits.Maybe someone else can give you more info about how to do it,or,get around it.I don't think you will be able to get OD without it tho.Again,I'm not sure about.There may be a way to bypass the circuit.
Old 07-04-2013, 12:37 PM
It should go into 4th gear without the lock up hooked up. Each time I had a tranny that didn't shift into 4th it was either the tv cable was not set correctly or just slightly low on fluid, just a quart or two low with cause this. You did top off the fluid with it idling in park right?
Old 07-04-2013, 05:28 PM
jokerZ71's Avatar
Wrench Turner
Low line pressure,a bad TC,low fluid,high fluid could all cause no shift to OD.Ckn fluid can be tricky on these things.Be sure you have drove far enuff that trans is up to normal operating temp.Place selector in ea gear for a few seconds then ck it.
700r4, overdrive
700r4 overdrive? rick gray Transmission - Rearend 1 01-11-2013 08:40 PM
700r4 vs overdrive bostonrpm Transmission - Rearend 5 05-03-2008 06:16 PM
700R4 No Overdrive ranlom18 Transmission - Rearend 1 10-29-2007 06:36 PM
Overdrive in 700r4 av8r Transmission - Rearend 2 08-04-2007 07:59 PM
700r4 no overdrive wwhijr Transmission - Rearend 4 06-07-2005 04:52 PM
