Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 not shifting right
Old 12-24-2012, 12:01 PM
123pugsy's Avatar
123pugsy 123pugsy is offline
Last wiki edit: Metal shaping
Wiki Edits: 29
Originally Posted by lowriderr9 View Post
Yeah it seems to be reving a little when I am on the gas a little more. As long as I a easy on the throttle its fine.
Did you give a few good tugs on the cable yet?
The tranny may not be on the way out yet. The cable system is more important than most guys realize.
Keep on it or else it will go out and if you rebuild it and there is a problem with your cable set up it will fry again.
I dropped my pan and found the problem before I lost a second tranny. It wasn't burying the plunger on the valve. It may not be your problem, but who knows, it could be too.
Do you have the correct bellcrank?
What carb is on the motor?
Crazy but true that only the governor can control shift points. Not the cable.
