700r4 OD gear Shifting Issue and TV cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2011, 07:26 PM
I just completed a 4.3 conversion on my 93 Wrangler. I installed the complete drivetrain from a 90 S10 Blazer. The issue I have is it will shift into each gear as I accelerate when it reaches OD and I am maintaining speed the trans will begin acting like it is shifting from 4th to 3rd to 4th to 3rd and so on. If I shift out of OD to drive it shifts to 3rd and stays there. What may be causing this? Also, I need cleared up the TV cable setup. I have read that to set the TV cable bracket at a distance so that when the throttle is at full WOT the TV cable is fulley pulled out. My question on this is, when I pull the cable end out it starts coming out with very little pull for like 1/2 inch the there is some resistance for 1/2 inch then there is heavy resistance (very hard to pull) until finally the cable dead stops. Do I set the brack distance so that at WOT the cable is at a dead stop or am I pulling it too far?
Old 01-29-2011, 10:51 PM
sqzbox's Avatar
My pipes are my music
The TV cable has a lot to do with it. To keep from relying on my memory, and save a lot of typing, Google "700R4 tv cable adjustment". The first site on the menu will tell you evrything you need to know.
Old 01-29-2011, 10:58 PM
The mobile view is crap
If the tv cable is old and you are having problems I would start by replacing it. They are around 25 bucks. I am sure the tv cable is the problem, if not that then maybe a worn out servo and its not holding overdrive.
Old 01-29-2011, 11:58 PM
sqzbox's Avatar
If you can't find the info or diagnosis. Contact (user name) tnsmith on this site. He'll steer you in the right direction.
Old 01-30-2011, 05:24 AM
tnsmith10's Avatar
when will it rain???
more than likely, if you wired in the T.C.C. (torque converter clutch), id be willing to bet that the problem is that its cycling in and out of "lock up".
as far as the tv cable setup, you are correct that the cable needs to be completely tight with the throttle wide open, or at a dead stop as you referred it.
tv cables will stretch, but unless the cable frays, or the adjustment doesnt hold, then theres no real reason to replace it unless you like spending money.
one last thing, if the shifts are late and firm, and you havent wired in the t.c.c., then odds are you are on the "failsafe" checkball and that you dont have the tv cable set far enough.
Old 01-30-2011, 09:59 AM
cont..
The 700R4 is all factory stock, however I installed a TCI lockup kit since I am not using the computer. I believe it suppose to only lock the converter when in 4th. Shifts seemed firm, I plan to test drive it again today and pay much more attention to the shift points. I dont have any gauges that work yet, Jeep tied theirs into the computer and since I am not using a computer even though I have them hooked up, they are not working so I dont have a working tach yet. I guess I could hook up my dwell/ tach meter to the HEI and route it inside so I can watch it.
Old 01-30-2011, 10:07 AM
cont..
I forgot to mention that the TV Cable is a brand new adjustable one from Jegs.
Old 01-30-2011, 10:37 AM
cont...
I have read some post that others have had issues with the TCI vac switch during lockup with cycling. Could I bypass the switch with a manual switch mounted inside and switch it on in 4th to see if it holds lockup or cycles?
Old 01-30-2011, 01:03 PM
SSedan64's Avatar
Yes, you can use a Toggle switch. Also there are adjustable Vacuum switches that will prevent the TCC cycling.
Parts & Info here>> http://www.rowand.net/Shop/Tech/Auto...issionSwap.htm
Old 01-31-2011, 04:12 AM
tnsmith10's Avatar
eliminate the vacuum switch. that is the cause of the cycling. its going in and out of lockup. we tried this on a customers car when we put in a 700r4 on a 70 1/2 z-28 camaro, and had nothing but problems. even tried another switch, and it did the same thing.
in the sticky part of this forum, crosley has a nice simple lock up wiring diagram, follow it and the problem will go away.
Old 01-31-2011, 11:55 AM
cont..
Ok thanks for all the help folks. This has been a nice conversion so far. One of my easier ones. Just a few sticking points here and there. The next thing I have to work on is the gages.
700R4 problem Shifting to 3rd gear Regular6d Transmission - Rearend 7 08-01-2010 12:29 AM
700R4 pressure issue in 3rd gear only! Cole Transmission - Rearend 0 02-04-2009 12:30 PM
700r4 not shifting out of 1st gear metalhead2910 Transmission - Rearend 1 08-09-2008 02:16 PM
700r4 shifting and 2nd gear . eliotmansfield Transmission - Rearend 4 06-20-2004 03:09 AM
700r4 not shifting out of 1st gear AKGMC Transmission - Rearend 2 06-08-2003 04:27 PM
