700r4 oil leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2012, 03:19 PM
700r4 oil leak
I finally have a 700r4 that shifts and behaves like It was supposed to. It only took two rebuilds and about 900 dollars in parts. Before I started this project I noticed a oil leak at the back at the pan. I thought to my self.. the rebuild should take care of that and gave it no further thought. Boy...was I wrong! It leaks in reverse. On the top right in front of where the transfer case attatches and a little bit toward the right a little bit of oil comes out when in reverse. The case either has a porosity or a small crack. My question is.....Can this be kinda fixed with a good prep and jb weld or am I wasting time. Instead should I look for a prepared case from a rebuilder or what. Any Ideas would be appreciated. Thankyou in advance
The Bone Man
Old 06-24-2012, 11:07 PM
BigChevyFTW
Guest
man you had some bad luck huh?
the 700R4 is an easy trans to rebuild and you can get them cheap at any pick n pull for 80 bucks
what i would do is get a good core and use all your parts just make sure its around the same year as yours because gm changed them a few times. you can also get a new case from just about any trans shop for 125 bucks.
Oil leak between oil filter adaptor plate and block HotRodMan Engine 3 04-23-2011 10:36 PM
700r4 leak Craig legacy Transmission - Rearend 1 04-23-2008 07:11 AM
Milky Oil and oil leak Parisienne70 Engine 4 04-27-2007 07:25 AM
HV oil pump makes oil filter seal leak WBrianS Engine 13 11-20-2003 01:56 AM
elusive 700R4 leak yenkonova Transmission - Rearend 7 09-27-2003 08:06 AM
