700R4 oil Leaks - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2010, 02:40 PM
Last journal entry: follow up
I have the same problem. In my case it is/was leaking around the housing for the speedo assembly. but after putting a new o ring in... well ... there was never one to begin with but i digress. it seems there is still a small leak somewhere.
as far as front passenger side that is where the dip stick goes in unless you have relocated it. those are prone to squirting from my experience unless they are seated and sealed properly. maybe check that. had to redo mine a few times to get it right.
Old 12-11-2010, 03:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
meenaismymonte;
welcome to Hotrodders.com
You posted to a very old thread. read the dates on threads when you search around
thanks for the information
