700r4 only has 1st and reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2006, 11:21 AM
my camaro recently started acting up with the trans. 1st iwas driving to work and it was holding the gear alittle longer. then when i was leaving from a stop i hammered on it and it shifted late but then it was in like neutral when i stoped it would only stay in first. any clue what the problem mey be. thaks rob
Old 06-03-2006, 11:51 PM
STRKD89FB's Avatar
408 Stroker
Have you tried readjusting the TV cable?? Be sure engine is off. Remove air cleaner, depress and hold the metal readjusting tab, then move the slider till it stops against the fitting then release the tab. Then manually open the tbi or carb lever to full throttle stop position and the slider will readjust its self then release throttle lever.
1st and reverse no drive or 2nd NIWROC Transmission - Rearend 4 12-22-2005 01:04 PM
General reverse and 1st gear ?s in auto trans scot Transmission - Rearend 3 12-17-2005 10:09 AM
700r4 Not Engaging ? edwardzracing Transmission - Rearend 8 10-07-2005 07:29 PM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 07:59 PM
New 700R4 no 2-3-OD just 1st JohnnyGTO Transmission - Rearend 6 06-30-2003 09:47 PM
