Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 only slipping in 2nd gear for 1-2 seconds?
Old 02-27-2012, 07:20 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
A ''little slippage' for 1 or 2 seconds is not good. Sounds like the band is damaged.
If you remove the servo for the band, look on it for numbers to learn what size the servo is. Post back when you can
