700r4 outer speedo gear not turning? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2006, 07:08 PM
Hi All,
I hang out mostly at 67-72chevytrucks.com, but found this site while researching 700r4 for my 1967 Chevy SWB truck. I have rebuilt this truck from the ground up, and now I am working out the bugs. One of the problems that I am having is that the outer speedo gear is not spinning. It appears that when in place, it is not getting turned by the gear on the shaft.
Has anyone had this kind of trouble?
Old 05-09-2006, 10:21 PM
Here is a cut away ...of a 700R4 ...
Look to see IF you have the driver gear ...
If you have a drive gear and it turns ... the driven gear must turn ... if everything is correct ...
Old 05-09-2006, 10:29 PM
have both gears...
thanks for that picture. I do have both gears, but it feels like the speedo gear (not the shaft gear) is not going in all the way.
I did see some notes on another web page that there are two speedo gear housings, and it is possible that may be my problem.
Old 05-11-2006, 06:56 PM
They do have two different ones ... one for the 34 to 39 tooth and one for the 40 to 45 tooth ...
Old 05-11-2006, 08:13 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
As Duece mentions the different tooth count groups for the speed-O bullet.... the 40 & higher tooth gear has a larger diameter shaft that passes through the speed-O bullet.
Gears and speed-O bullets must match .
Old 05-11-2006, 10:12 PM
Chopt 48's Avatar
Here is a good link for speedo gear info. It gives, ratios and tells how to calibrate along with what matches up.
http://www.tciauto.com/tech_info/speedo_gears.htm
I would have to agree that It either doesn't have a drive gear or the gears don't match.
Old 05-11-2006, 10:40 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
IF you have difficulty installing the speed-O bullet with the correct driven gear, Like the speed-O bullet goes most of the way into the hole but not all the way. It is possible somebody installed a plastic gear on the output shaft that is a t-350 speed-O gear.
A t-350 gear fits on the output shaft fine , but the gear is too large in diameter and will not function correctly in the 700 / 4L60 tranny
Old 05-13-2006, 11:15 AM
Chopt 48's Avatar
The picture tha Duece posted came from this website. He has a bit more info han the TCI site that I posted before.
http://www.transmissioncenter.net/sp...n_______va.htm
My feeling is that either you have the wrong gear housing and or the wrong gear. Or the drive gear was left off .
The other thing may be (if it is a used trans) that one of the gears was stripped before you got the trans. Locked up cable in doner car.
Have you jacked the car up to see if the gear is actually turning. You can probably tell this by turning one wheel or the driveshaft If the car has cruise control Is it turning on the output side of the gear box? I have had one of those go bad.
Old 05-13-2006, 11:43 AM
fixed....
Hi All,
It was the wrong housing for the gear set I was using. Got the right housing, and all is working now!!!!
Thanks!!!
big power loss at 4 g's only in 3rd gear (700r4) mason71 Transmission - Rearend 4 03-26-2005 10:32 AM
Towing in 3rd with a 4th gear lock up kit in 700r4 wed68 Transmission - Rearend 4 03-25-2005 12:34 PM
More TECH On FORD Dist. Gear Failure KULTULZ Engine 8 03-18-2003 04:50 AM
Best gear ratio when installing 700r4 transmission agordon Transmission - Rearend 6 02-18-2003 08:05 AM
TH-400 Speedo Drive Gear Replacement 454impala69 Transmission - Rearend 6 03-17-2002 03:03 AM
