Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 output shaft
Old 02-08-2012, 05:26 PM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by JTGochenour
i am rebuilding my 700r4 and have ran into a problem. my output shat will not go all the way in. i am not able to get the snap ring into the groove. the shaft only needs to go in about another half a cm. maybe i have a bearing or thrust washer in the wrong place? anybody with any suggestions, please help.
its possible that you have a roller washer slip out of place if you have the trans on its side from the front planetary or, if youre not using any assembly lube to hold a plastic washer in position, that could also be the case.
the hub that goes down at the bottom of the case on assembly is also staked and ive seen at times the output shaft doesnt go in all the way by hand and have had to take a rubber mallet to tap it in all the way.
