700r4 output shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2012, 09:18 AM
700r4 output shaft
i am rebuilding my 700r4 and have ran into a problem. my output shat will not go all the way in. i am not able to get the snap ring into the groove. the shaft only needs to go in about another half a cm. maybe i have a bearing or thrust washer in the wrong place? anybody with any suggestions, please help.
Old 02-08-2012, 05:26 PM
tnsmith10's Avatar
when will it rain???
its possible that you have a roller washer slip out of place if you have the trans on its side from the front planetary or, if youre not using any assembly lube to hold a plastic washer in position, that could also be the case.
the hub that goes down at the bottom of the case on assembly is also staked and ive seen at times the output shaft doesnt go in all the way by hand and have had to take a rubber mallet to tap it in all the way.
700r4 output shaft splines mitcht2005 Transmission - Rearend 1 05-18-2011 06:07 PM
700r4 loose output shaft jacko3 Transmission - Rearend 5 10-15-2009 12:36 PM
700r4 trans output shaft question johnboy24 Transmission - Rearend 10 08-20-2009 04:46 PM
700r4 output shaft swap pwchevyman1990 Transmission - Rearend 5 12-07-2008 10:00 AM
Changing Output Shaft in 700r4 70bird Transmission - Rearend 12 12-05-2006 05:15 PM
