700r4 output shaft splines - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2011, 04:24 PM
OK, am i losing my mind or what. i thought the splines on the output shafts on a 700r4 didnt change the length i know there are different amounts. were there certain years they were shorter splines? the out put shafts themselves are the same length but the splines are 1/2 inch shorter intern not letting me slide drive shaft yoke in all the way .
sorry for the lack of info its a 700r4 92 2twd ill get some pics of the difference im going out now to pull the trans back out
Old 05-18-2011, 07:07 PM
pics of 700r4
both 700r4 trans
700r4 loose output shaft jacko3 Transmission - Rearend 5 10-15-2009 01:36 PM
700r4 trans output shaft question johnboy24 Transmission - Rearend 10 08-20-2009 05:46 PM
700r4 output shaft swap pwchevyman1990 Transmission - Rearend 5 12-07-2008 11:00 AM
Changing Output Shaft in 700r4 70bird Transmission - Rearend 12 12-05-2006 06:15 PM
transmission 700r4 output shaft slop catscan4free Transmission - Rearend 3 01-25-2004 09:11 AM
