700r4 output shaft swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2008, 09:19 AM
pwchevyman1990's Avatar
Hey guys first post
i was wondering what it takes to change an output shaft from a junk 4x4 700r4 to a 2wd 700r4 thats good? ive heard you need to basically teardown the whole tranny to do it and i have also heard you can just cut the outputshaft down 1.5 inches and that will work for bolting up to the t-case?????
also if i get a 4l60 4x4 tranny will that bolt right up no problems what so ever?
thanks for the help
Old 12-05-2008, 09:52 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by pwchevyman1990
Hey guys first post
thanks for the help
the 700-r4 and the 4L60 trans are the same transmission.
You can not cut the longer shaft off to a 4x4 length out put shaft .
the trans must be disassembled about 1/2 into the internal parts to swap the shafts. It is not a job for a non experienced person
Old 12-05-2008, 09:53 AM
SSedan64's Avatar
Read these 2 posts for some Info. I'm not sure about the cutting option.
700r4 output shafts
tranny mainshaft ?
Old 12-05-2008, 12:26 PM
thank you both
so the 4l60 can just be directly swapped with the junk 700r4?
Old 12-05-2008, 12:49 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
thank you both
A 4L60 is the same trans as a 700r4. GM renamed them.
Do not confuse a 4L60E with the non electronic 700 /4L60.
The 4L60E trans has an electrical connector on the passenger side of the trans about 1.5 inches in diameter. There is no TV cable on the 4L60E
Old 12-07-2008, 10:00 AM
thank you crosley
700r4 output shafts stuvand Transmission - Rearend 2 05-15-2008 06:12 PM
700r4 Trans Swap DWALL2N Transmission - Rearend 4 03-23-2008 10:27 PM
Different size output shaft on c4? nitrous_69stang Transmission - Rearend 3 04-17-2006 10:51 AM
transmission 700r4 output shaft slop catscan4free Transmission - Rearend 3 01-25-2004 08:11 AM
700r4 tranny swap chevcamz28newbie Transmission - Rearend 6 08-06-2003 01:52 PM
