700r4 output shafts - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2008, 02:14 PM
700r4 output shafts
i have a 2wd 84 chev c10. i had a 700r4 in it but cracked the bellhousing so i bought a new 700r4 out of a 4x4 pickup. i need to change the output shaft because the output shaft that is in it now is meant to go in the transfer case. i was wondering if anyone could tell me how to pull the 4x4 output shaft out and put my old output shaft in. thanks
Old 05-15-2008, 03:06 PM
SSedan64's Avatar
You're going to have to completly dissasemble both trans. The output shaft is one of the first parts that goes in when building a trans & the last part that comes out when dissasembling.
Old 05-15-2008, 06:12 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the 700 trans needs to be dis assembled about 1/2 way into the case. the out put shaft installs from the rear of the case after a snap ring is removed.
IF you are not familiar with this trany , i would suggest finding some knowledgeable to avoid a costly mistake
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 02:04 PM
Changing Output Shaft in 700r4 70bird Transmission - Rearend 12 12-05-2006 05:15 PM
Are all C6 output shafts 31 spline? Rustydawg Transmission - Rearend 1 11-25-2004 09:27 PM
transmission 700r4 output shaft slop catscan4free Transmission - Rearend 3 01-25-2004 08:11 AM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
