700r4 parts build suggestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2010, 04:21 PM
i have searched but i will ask for some options,i run a 454 with a towing cam,highrise daul plane with a q-jet in a 1962 gmc suburan.it will never see a dragstrip.that being said i do have a heavy foot. i will sometimes haul a small 17 foot camper.i have been using a junk yard 700r4 stock form for several years till it quit shifting. i have read the beast shell, corvette servo ,500psi piston and differant govenor.what parts do i need for a good heavy duty towing transmission.how about the valve body that keeps up the pressure sold at summitt. i have got cd video and a haynes manual.thanks ken
Old 07-05-2010, 09:19 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You have a start on a good list of parts.
You post " what parts do i need for a good heavy duty towing transmission"
A 700r4 trans is not really a heavy duty towing trans.
Do you know the combined weight of vehicle and trailer you plan on towing?
Old 07-05-2010, 01:09 PM
700r4
thanks for the reply. i think the suburan weights in at 4500 lbs and not sure of my camper it is a single axle 1967 shasta , i gues that i mean a transmission that cn surive behind the 454 , the trans i`am going to build i think is 1987 by the numbers stamped on the passenger side. i have been driveing this combo for several years with this junk yard trans. my local trans guys says i need a 400 but i sure like the over drive thanks
Old 07-05-2010, 01:19 PM
700r4
thanks for the reply. i think the suburan weights in at 4500 lbs and not sure of my camper it is a single axle 1967 shasta , i guess that i mean a transmission that can surive behind the 454 , the trans i`am going to build i think is 1987 by the numbers stamped on the passenger side. i have been driving this combo for several years with this junk yard trans. my local trans guys says i need a 400 but i sure like the over drive .how about the valve body that keeps the pressure up , thanks
which 700r4 to use and other parts? TheCiscoKid Transmission - Rearend 7 08-13-2008 09:05 PM
do it right the 1st time, strong 400 short block budget build, stock parts? Warrant Engine 9 12-04-2006 07:29 PM
Need suggestions on 350 build pete379 Engine 3 06-14-2005 10:10 AM
450hp engine parts build up mgray10 Engine 11 02-03-2004 08:18 PM
700r4 parts and lockup wiring McDeuce Transmission - Rearend 17 12-17-2003 07:52 PM
