700R4 plunger - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2007, 07:45 AM
700R4 plunger
With your help I fixed my 1-2 harsh shift. While I had the pan off the plunger only had three rings showing at closed throttle. The Bowtie website shows about six rings showing. I have the Holley bracket installed and set the cable per instructions. I just feel like the shifts are not correctly spaced. Any suggestions?
Thanks
Don
Old 11-13-2007, 10:09 PM
700r4 Plunger
I guess I am asking. How far does the plunger stick out of the case. My plunger sticks out about 1.5 inches with 3 rings showing, Is this normal or should there be more rings showing,
Thanks
Don
Old 11-14-2007, 06:45 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
Don
Here is a photo of the plunger fully extended.
I am not sure I understand your post IF your plunger is stuck or not .... OR are you talking about the linkage holding the plunger 'in' slightly.
Minimum basic TV cable setting with the throttle closed should have the plunger 'out' as in the photo.... the linkage foot should just slightly touch the end of the plunger. Final adjustment may be slightly away from the plunger or slightly depressing the plunger.
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 02:04 PM
Rebuilding a 700R4 in 4x4 for towing... indy_85stariones Transmission - Rearend 4 02-02-2007 01:26 PM
700r4 TV Cable Problem jack71 Transmission - Rearend 7 10-25-2006 08:05 PM
700r4 TV plunger spring AngliaBob Transmission - Rearend 3 01-30-2005 08:17 AM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
