700R4 Pressure
Hi All,
I have a 700r4 in my GMC Jimmy 6.2 Diesel. It has a transmission that was "GM Certified" rebuilt...it has burned the 3-4 clutches twice. The TV cable is adjusted correctly; however pressure is a constant 120 PSI in all forward gears and over 200 PSI in reverse (my gauge only goes to 200). Pressure does not change when the TV cable is pulled or when the engine is accelerated. Any ideas? I'm thinking it's a stuck boost valve? Both times the clutches burned the transmission was under a heavy load...hauling a trailer and when engaged in 4WD while in snow. |
Usually no 'line rise' (pressure) would indicate a stuck throttle valve..
| The Following User Says Thank You to C-10 For This Useful Post: | ||
Edgar86 (11-21-2012) | ||
Since you have higher psi in reverse , that indicates the 2nd boost valve is operating look at sizes of the boost valves too. You are replacing parts and not fixing the problem as you have now discovered
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| The Following User Says Thank You to Crosley For This Useful Post: | ||
Thank you for your replies. I will hopefully be digging into the transmission this weekend. I'll be sure to check all valves and look for leaks...I don't want to be changing out 3-4 clutches every couple of thousand miles!!
| 700r4 line pressure? | blacklabzeke | Transmission - Rearend | 5 | 10-25-2012 08:56 PM |
| 700r4 - No pressure change | garari | Transmission - Rearend | 10 | 11-29-2011 09:29 PM |
| 700r4 - low pressure? | danbo | Transmission - Rearend | 4 | 04-30-2008 01:38 PM |
| 700r4 low pressure | hudsonman | Transmission - Rearend | 3 | 11-06-2006 09:49 AM |
| Low pressure 700R4 | AngliaBob | Transmission - Rearend | 1 | 02-26-2005 09:05 PM |
