700r4 prob. maybe miner? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2008, 04:45 PM
rotbox's Avatar
ok names kenny i have an 85 chevy 3/4 and i recently put a 350 in since i couldnt fit my th350 tranny in it i left the 700r4.drove it prob. 2 days now it seems to be stuck in low or overdrive.shifts into drive and reverse fine but doesnt switch gears.I may be the cause of the prob. since i didnt hook up the tree wires that come out of it.and i hear theres supposed to be vaccume?ok also the t.v. cable may have not been adjusted properly.now i'm at the point i got the pan off new t.v. cable and i'm gonna throw everything together and try and hook up the wires(vaccume).And adjust the cable correct and hopefully it works.now if it doesn't is it burnt out(time for a new one).is there anything else i can do or check.what is the prob?
thanks to anyone who responds.
p.s. this site is cool i will put in some suggestions
Old 04-09-2008, 10:31 AM
check vacum and and also fluid but sounds more like a vacum not hooked up
Fordmann
Old 04-09-2008, 10:45 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
The TV cable needs proper adjustment AND travel (pull). To save a bunch of typing here's a link to all you'd ever want to know about the TV system on a GM overdrive. There are no vacuum modulators on a TH700R4.
http://www.tvmadeez.com/tvcable_inst...stockcable.php
Old 04-09-2008, 01:22 PM
rotbox's Avatar
ok i will hook up the vacuum and try it again
c-10 i dont know if it has vacuum modulators or not but the trans has 3 wires coming off it and on the 305 i took outta there they where hooked up to lines on the carb so i don't know.which i think are for vaccum?
if i understand right the t.v. cable just controls the overdrive and it should still shift even if it's not hooked up correct?either way it wouldn't stop shifting if it wasn't adjusted perfect?
again it's an 85 chevy 3/4 ton 2wheeldrive.the trans is new but the same one that it replaced.it had a 305 in it(with all the pollution STUFF on it).I put a 350 in it drove it for 2 days now theres no 2nd,3rd,or 4th.just low.
THANK YOU both for your help any other ansers,comments,questions, or suggestions are GREATLY APPRECIATED.
p.s.might have spelled that wrong sorry
Old 04-09-2008, 01:50 PM
C-10's Avatar
Revolution Calling
no no no!
The TV cable is the ONLY link to the outside world your trans has. It follows the throttle position at all times and varies line pressure combined with the governor speed to make your trans shift. Your new trans won't last long if this the TV cable is not connected. All gears 1,2,3,4 need to have the TV cable hooked up. For the sake of your transmission's life expectancy, get that TV properly hooked up. Go here http://www.tvmadeez.com/ and read all you can. Look at their installation guides.
The square plug on the left side is for your torque converter lock-up feature. Think of this as kind of a 5th gear. The small vacuum hose connects to a vacuum operated electrical switch that tells the converter to lock at light throttle loads. This will help fuel mileage some. This vacuum line isn't for shifting- like the old TH350's had.
If I lived closer, I'd come and help you and your old truck out!
Old 04-10-2008, 02:08 PM
rotbox's Avatar
thank you c-10
ok i don't have to tell you how much that info helped me......You already know!so i hooked everything up as good as i could.adjusted the TV cable pretty good i'm sure.It does shift now but......first to second doesn't shift right away races out abit before it shifts.what could this be(assuming it's not the TV cable)it shifts good it is ONLY 1-2 it stutters.
any input at all is greatful!
thank you again C-10 for helping my old chevy truck.
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 03:04 PM
Rebuilding a 700R4 in 4x4 for towing... indy_85stariones Transmission - Rearend 4 02-02-2007 02:26 PM
700R4 help/advice Mustangsaly Transmission - Rearend 7 12-12-2005 05:54 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 04:34 AM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 07:44 PM
