Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 Problem
Thread: 700R4 Problem
Old 12-26-2011, 05:13 PM
pricesgarages's Avatar
pricesgarages pricesgarages is offline
tv cable setting is definally important the lock up drops rpms about 300 rpms by locking the torque converter directly to the transmission elemating slippage it is done electricly unless a mechanical lock up conversion has been done .Under normal driving it should shift about 2500 rpm give or take afew rpms like mentioned in the aboved post you have to hsave the correct tv linage and adjustment
